Salutare tuturor,
Vand o pereche de boxe AVI ADM9.1T, asamblate manual in Anglia, cumparate de mine direct de la producator in urma cu vreo 2 ani, poate 3. Inainte sa le iau am cautat foarte mult pentru ca vroiam un sistem minimalist complet (amp, preamp, dac) si evident, un sunet foarte bun. Le vand pentru ca trebuie sa plec din tara o perioada lunga si ar fi prea complicat sa le transport.
Specificatii tehnice:
Culoare: alb lucios
Power amplifiers - High speed, linear, analogue bipolar, 75 WPC for the tweeters and 250 WPC for the bass drivers. Distortion is typically better than 0.002% with a dynamic range of 120 dB.
Crossovers- High quality 4th order Linkwitz Riley discrete analogue.
Preamplifier - High performance, state of the art analogue preamplifier with two digital and one analogue input. Operation is via infra red remote and volume settings are remembered for each individual input. Analogue input feature fixed gain capability for easier integration with home theater and multi-channel audio applications.
DAC- State of the Art Wolfson 24/192, completely jitter free design.
Bass driver - Very high power handling 6.5" paper cone drive unit with 1.5" voice coil and exceptionally broad bandwidth, thus enabling a phase perfect crossover at 3.4 kHz. Bass extension rated to better than 60Hz (-6dB).
Tweeter - 1" Silk Dome tweeter with 28 kHz extension (-3dB).
System Amplitude response better than + or - 2 dB, 100 Hz - 20 kHz.
Max continuous SPL (both speakers driven at 1m, 100 hr rating) 108dB with +8dB headroom.
http://www.avihifi.co.uk/products.html" onclick="window.open(this.href);return false;
http://www.whathifi.com/avi/adm91/review" onclick="window.open(this.href);return false;
http://www.computeraudiophile.com/conte ... -1-review/" onclick="window.open(this.href);return false;
http://www.gramophone.co.uk/editorial/a ... lternative" onclick="window.open(this.href);return false;
http://www.soundonsound.com/sos/feb08/a ... viadm9.htm" onclick="window.open(this.href);return false;
Folosesc boxele impreuna cu un subwoofer Monitor Audio Bronze BXW-10, care este si el de vanzare. Stare impecabila.
http://www.monitoraudio.co.uk/products/bronze-bx/bxw10/" onclick="window.open(this.href);return false;
POZE: http://1drv.ms/1taFWI4" onclick="window.open(this.href);return false;
Pret lista AVI ADM9.1T: 1200 lire sterline
Pret lista Monitor Audio BXW-10: 1990 lei
Pret vanzare boxe: 5.250 lei
Pret vanzare boxe+subwoofer: 6.550 lei
Contact: 0722.201.091
Anuntul este valabil doar pentru Bucuresti.
Vand boxe active AVI ADM9.1T
Re: Vand boxe active AVI ADM9.1T
Pret nou sistem: 6100 lei
