Ora este UTC [ DST ]
Scrie un subiect nou Răspunde la subiect  [ 1 mesaj ]
  Versiune printabilă
Vand pick-up Roksan Radius 5
Autor Mesaj
MesajScris: 26 Mar 2017, 13:59
Neconectat
Vand pick-up high end ROKSAN Radius 5 MK II. Culoare negru lucios,(black piano) platan alb, acrilic. Brat Nima si doza MM Corus, conceptii proprii ale producatorului britanic.Sunet exceptional, deosebit. Pick-upul a fost premiat de revistele de de specialitate, recomandat pretentiosilor,
Design aparte.
Motivul vanzarii este upgradeul, ascultatorii autentici de vinil cunosc sentimentul
Pret de achizitie 1699 Pounds
Pretul meu 5500 lei Bonus puck stabilizator eFly audio.
Pick upul are doza instalata si este setat pentru auditie.
Produs in garantie.
The new Radius 5 Mk II builds on the strengths of the award winning Radius 5 by further enhancing the performance, compatibility and even the aesthetic.
From its new Motor mount to the new polished stainless steel feet, the new 5.2 manages to combine beauty, elegance and true high-end performance all in one package.
Key Features:
New High Tolerance Main Bearing
Optimised Motor Power Supply
Upgraded decoupling and Motor suspension mounts
New custom made silicone Drive Belt
Improved coupling to supporting structure
New polished stainless steel feet with silicone coupling
Enhanced aesthetics
Black Acrylic finish
New improved Nima tonearm Pillar Holder
Improved Nima Unipivot bearing pillar
New custom made High Rigidity Arm Tube
New Head-shell and Bearing Yoke attachment to Arm Tube
Improved Anti-skate system
New optional Heavy Counter Weight
New improved Internal wiring
Radius 5.2 Power Switch Suppression Capacitors Upgrade
Can be fitted to all Radius5 MkII
Technical Data:
Main Bearing Spindle: Precision Machined Stainless Steel
Main Bearing Housing: Precision Machined Solid Brass
Main Bearing Ball: Precision Case Hardened Steel
Pulley: Precision Machined Aluminium Alloy
Platter: Precision Machined Acrylic
Motor: Custom Made 24 Pole Synchronous
Speed: 33 & 45 RPM
Power: 110 or 220V A/C – 50/60 Hz
Sus
 Profil
Afişează mesajele din ultimele:  Sortează după
Cine este conectat
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat
Nu puteţi scrie subiecte noi în acest forum
Nu puteţi răspunde subiectelor din acest forum
Nu puteţi modifica mesajele dumneavoastră în acest forum
Nu puteţi şterge mesajele dumneavoastră în acest forum
Nu puteţi publica fişiere ataşate în acest forum
Căutare după:
Mergi la:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Translation/Traducere: phpBB România
