Ora este UTC [ DST ]
Scrie un subiect nou Răspunde la subiect  [ 4 mesaje ]
  Versiune printabilă
Vand: cabluri, stand-uri, sistem antivibratii, cd-player
Autor Mesaj
MesajScris: 05 Feb 2018, 15:37
Neconectat
Localitate: Viseu de Sus, Maramures
Am mai multe produse. Pentru detalii suplimentare sau poze rog contact: 0747111473.
Preturile sunt negociabile.
1. Cablu phono Supra Biline MK II
Lungime: 1 m
Pret: 199 lei
Phono 2 RCA Including ground connection.
An interconnect of low capacitance.
Each pair of the Biline cable is shielded with an Aluminium/Polyester foil.
The screen provides efficient protection from ’hum’ and noise caused by electro–magnetic fields.
The semi–balanced connection configuration makes Biline cable secure with furthering immunity to electro–magnetic interference, i.e. it makes it noise free.
2. Cablu boxe Supra Ply 3.4/S (Shielded) - 2x3.4 mm² sandwich design
Lungime: 2 x 2.5 m
Pret: 190 lei
Ply combines low induction and tin plating which provides for explosive dynamics. Ply is a multi-award winner and one-of-a-kind quality cable from SUPRA.
"The Supra Ply 3.4 S is, given the price, simply outstanding.Neutral and balanced it possesses a very deep bass range, good transient response and a very good 3D imaging. It is not expensive (I'd say cheap...), it is not as "fat" as some ridiculously oversized competitor, it is user and living-room friendly and it is easy to match with a large number of amps and loudspeakers.Despite its low price it can successfully compete with very expensive and "esoteric" competitors. A winner."
SPECIFICATII TEHNICE
Cross. Area: 3.4 / 12 mm2/AWG
No. Conductors: 2
No. Wires: 192
Wire Diameter: 0.15 mm
Wire Material: Tin Plated OFC
Insulation: Heat & ageing resitant PVC
Screen: Braid 120x0.15
Screen Coverage: 95%
Ext. Size: 7.3x7.3 mm
Weight: 156 g/m
http://www.tnt-audio.com/accessories/ply34s_e.html
http://www.jenving.com/products/view/pl ... 1000000685
3. Interconect Chord Chameleon Silver Plus
Lungime: 1 m. Ambalaj original.
Pret: 100 euro
Descriere
Triple conductor set, floating shield configuration
Silver-plated oxygen free copper conductors and shield
Teflon dielectric
Silver-plated RCA plugs
Specificatii
CONDUCTORS: 4 x 26 AWG multi-stranded silver-plated oxygen free copper
CONFIGURATION: Single signal and dual return conductor configuration. Improves bass detail and definition, music sounds natural and coherent.
CONDUCTOR INSULATION: PTFE. We believe that to obtain the most neutral tonal characteristic from silver-plated conductors it is vital to use PTFE insulation. Conductors are over wrapped with cotton fibre to improve mechanical noise rejection.
SHIELDING: Dual layer; high density, lapped oxygen free copper shield and overlapped foil shield
JACKET: Conductors encased in soft PVC to reduce mechanical noise, protective outer layer.
https://www.whathifi.com/chord-company/ ... lus/review
4. Interconect Accuphase AL 10
Lungime: 1m. Ca nou, impecabil.
Pret: 150 euro
Un super cablu, la un super pret! Cel mai mic de pe piata.
http://www.accuphase.com/model/ofc_cable.html
5. Interconect Viablue NF-S1 Quattro Silver
Lungime 80 cm
Pret: 190 lei
Specificatii:
- cupru OFC liţat, placat cu Argint,
- ecranat (ecran dublu din Aluminiu placat Argint şi pet),
- cămaşă pvc negru, 2 cabluri răsucite de 19 x Ø0,185mm fiecare, cu izolaţie de polietilenă
- diametrul exterior este Ø9mm.
- engineered in Germany
Mufe: RCA Audio Alchemy HEX-Gold (6.5 euro/buc, adica 120 lei doar mufele!)
Camasa de protectie Viablue Black
6. Sistem antivibaratii Omicron Magic Dream - un set de 3 bucati.
Pret: 110 euro
Pentru audiofilii cu pretentii!
Sistem cu bila care elimina vibratiile atat pe verticala cat si pe orizontala.
Un cd-player sau pick-up pus pe acest sistem este imun la viratiile exterioare.
7. Placa antivibratii by chrissugar
Pret: 130 euro
Pentru audiofilii cu pretentii.
E o placa antivibratii potrivita/gandita pentru surse in special: pick-up, cd-player. Sunetul e mai curat, totul e mai clar, microdetalii mai evidente, focus, separatie mai precise.
Aceste aparate nu se pun pe sticla sau placi de granit si marmura pentru ca aceste materiale amplifica vibratiile interne din aparate. Aceasta placa preia vibratiile, deoarece e facuta dintr-un material special, compozit. A fost gandita si executata de un inginer din domeniul audio care a activat pe forum-urile audio vechi unde a si prezentat-o. Au fost executate doar cateva bucati, cererea a fost asa mare ca nu a facut fata si a renuntat sa mai faca.
Dimensiuni: 48/35/5 cm
Greutate: 12 kg
8. Standuri boxe din lemn masiv, din stejar de 7x7 cm. Grele, masive, solide si stabile.
Facute special pentru boxe Spendor SP 2/3.
Pret: 799 lei
Se potrivesc si pentru alte boxe de raft de dimensiuni mari, de exemplu Harbeth, dar si pentru alte boxe mai inalte. Pe standurile clasice boxele cu inaltime mai mare au tweeter-ul prea sus. Urechea trebuie sa fie la mijlocul distantei dintre diful de inalte si medii/bas.
Dimensiuni: 27/32/46
Greutate: 10 kg/buc.
Recomand spikuri soundcare. Pe aceste standuri boxele suna mult mai bine, la adevarata valoare.
9. CD-player NAIM 5i mk II sau italic.
Impecabil, ca nou, in cutia originala.
Telecomanda si cablu DIN.
Pret de nou: 1250 euro
Pretul meu: 599 euro
_________________
Sus
 Profil
Re: Vand: cabluri, stand-uri, sistem antivibratii, cd-player
MesajScris: 11 Feb 2018, 18:35
Neconectat
Up!
Oferta: transport gratuit!
_________________
Sus
 Profil
MesajScris: 17 Feb 2018, 08:46
Neconectat
Actualizare: cablurile Accuphase si Chord nu mai sunt disponibile!
_________________
Sus
 Profil
MesajScris: 27 Feb 2018, 20:50
Neconectat
Actualizare: cablul Supra phono Bi-line, standurile si cd-ul Naim nu mai sunt disponibile!
_________________
Sus
 Profil
Afişează mesajele din ultimele:  Sortează după
Cine este conectat
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat
Nu puteţi scrie subiecte noi în acest forum
Nu puteţi răspunde subiectelor din acest forum
Nu puteţi modifica mesajele dumneavoastră în acest forum
Nu puteţi şterge mesajele dumneavoastră în acest forum
Nu puteţi publica fişiere ataşate în acest forum
Căutare după:
Mergi la:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Translation/Traducere: phpBB România
