Super Oferta! Spendor S8e !!!
DanielTr
Post by DanielTr »
Pret fix : 1200 Euro - fara alte negocieri sau schimburi! ROG SERIOZITATE!
Modalitate de contact: 0765469303
Modalitate de plata: Ramburs
Starea: Second Hand
Garantie: Nu
Cantitate: 1
Oras: Craiova, Dolj
Modalitate de livrare: Predare personala
Boxe audiofile Spendor S8e
Description
2-way floor standing loudspeaker
Enclosure type - Spendor linear flow reflex
HF drive unit - 27mm fabric dome with fluid cooling
MF / LF drive unit - Spendor 210mm ep38 cone
Sensitivity - 87dB for 1 watt at 1 metre
Crossover point - 4 kHz
Frequency response - 47 Hz to 20 kHz ± 3dB anechoic
Typical in-room response - -6dB at 37 Hz
Impedance - 8 ohms nominal
Impedance minimum - 4.0 ohms
Power handling - 200 watts unclipped programme
Terminals - 2/3 way binding posts bi-wired
Cabinet (HxWxD) - 925 x 226 x 320mm
Finish - rosenut
Weight - 25 kg each
Boxele sunt in stare impecabila, vin impreuna cu spike-urile, grilele frontale, cutiile originale, etc. Se pot asculta in Craiova. Prefer predarea personala insa in caz de necesitate le pot trimite in tara.
Pentru cunoscatori boxele nu mai au nevoie de niciun fel de alte recomandari.
http://www.6moons.com/audioreviews/spendor/spendor.html" onclick="window.open(this.href);return false;
http://www.audioreview.com/cat/speakers ... 94crx.aspx" onclick="window.open(this.href);return false;
http://www.whathifi.com/review/spendor-s8e" onclick="window.open(this.href);return false;
http://www.avguide.com/review/spendor-s8e-loudspeakers" onclick="window.open(this.href);return false;
http://www.spendoraudio.com/HTML/S8e_specification.html" onclick="window.open(this.href);return false;
Pentru mai multe detalii va stau la dispozitie!
