ZU AUDIO OMEN
alex65
ZU AUDIO OMEN
Post by alex65 »
Boxe ZU AUDIO OMEN,din SUA,noi august 2012.Description
High effi ciency, high output, direct radiating fl oor standing loudspeaker. Omen features Zu’s full-range driver
(Zu260FRD/G4), Zu-Griewe driver/box/room loading technology, no crossover or fi lters on full-range driver,
complimented by a composite dome time-aligned machined from billet tweeter to provide the acoustic sparkle and
resolution from 12kHz and up.
Zu / orthogonal Scandinavian
36 x 12 x 12” [92 x 30.5 x 30.5cm] each
53 pounds [24kg] each
FlexPak foam encapsulated 44 x 17 x 17” [112 x 43 x 43cm] 60 pounds [27kg] each
34—25kHz
98dB SPL @ 1W, 1m
12Ω, nominal full bandwidth
30” [76cm] adjustable via footers and subtle canting of loudspeaker system
40°
40°
3 feet [1m] or more
via standard 5-way binding posts: 1/4” spade [6.3mm], oversized 5/16” [8mm] spade, bare wire, banana plugs
ZuMission hookup wire
4—12 watt (average room, moderate volume)
12—36 watt (large room, loud listening)
36—200 watt (large room, concert levels)
300 watt (maximum input power)
anything that sounds good (fl oating load, any amp type or circuit is fi ne)
better than 1% driver pair matching, 0.1% on all other electrical components
1x Zu APT-L2 tweeter assembly with stainless screen // bandwidth: 12k—25kHz
1st order bessel @ 18kHz (12kHz acoustical) PulseX 1uF + 10Ω 10W R
1x Zu260FRD/G4, 10-1/3” full-range driver // bandwidth: 30—12kHz (direct and unfi ltered)
North American MDF skinned with real wood veneer
3/8–16 TPI, 9/16” hex nut, 14mm wrench can be used
2x hard press-on full-range driver covers, installed
8x hard surface stainless ball-end feet / 8x stainless 9/16” [14mm] jam nuts, installed
8x long carpet spikes
1x instruction booklet.
  • Pret.1600E tel.0723599410
(16.22 KiB) Downloaded 380 times
Accuphase E-408,Yamana cds1000,Musical Fidelity M6 cd,Musical Fidelity M1 Click,Usher BE-718DMD,ProAc Studio 130
alex65
Re: ZU AUDIO OMEN
Post by alex65 »
SOLD !
