"The most advanced CD playback system ever designed"
The Memory Player is the most advanced CD playback system ever designed.
What's Wrong With Conventional CD Players?
Music is fluid, seamless, natural. Over two decades have passed since the introduction of CDs, and we still, for
the most part, prefer old vinyl reproductions to even state-of-the-art digital playback. There are powerful reasons
for this, but in essence, it can be reduced to a single tenet: Virtually ALL complaints against digital sound can be
reduced to byproducts of the dissection of music into fragments, and an attempt to reassemble them perfectly.
The dissection of a continuous music stream into "quanta", and reassembly attempts, always create TIME errors
and play bits at the incorrect moments in time.
http://www.novaphysicsgroup.com/TheMemoryPlayer.html
http://www.novaphysicsgroup.com/index.html
Re: "The most advanced CD playback system ever designed"
Deci, care este impresia voastra ? Ar fi real tot ce se spune acolo ?
Greu de spus daca e cel mai tare din parcare sau nu .
Kostas
Post by Kostas »
Lector, il cumperi, testezi si ne spui si noua cum suna :D
Pai l-as lua ca sa-l testez apoi il returnez ! Sint un pic ocupat acum !
CC_TM
Post by CC_TM »
Eu sunt foarte optimist in privinta music serverelor si o vad ca solutie ce se va impune pe viitor. Mi se pare logic ca redarea din memorie sa se apropie cel mai mult de redarea perfecta.
CC_TM
nu te supara ca-ti spun....dar si multora li se pare logic ca nu are cum sa conteze un biet cablu de curent! (din moment ce ai cablu prost de la trafo la tabloul casei si apoi altul prost pana la priza! :D ...Logic, nu?! :lol: :lol: :lol: )
CC_TM
Post by CC_TM »
:D :D :D
Stiu ca sunt multe chestii aparent logice dar fara efect scontat, dar in cazul redarii din memorie chiar "mi se pare logic" sa se apropie de perfectiune :P
Ramane de vazut daca logica mea o sa aiba succese practice.
nicumur
Post by nicumur »
Da, baieti dar, pentru a reda din memorie - (care, intr-adevar este o redare perfecta (sau, mai bine zis mult mai buna decat cea "directa)) trebuie mai intai citit materialul aflat pe suport - iar asta este cu totul alta mancare de peste... :wink:
asta cu transferul de la suport (discul optic) la bufferul de memorie e buba mare de tot.
Dar, nefiind deloc in cunostinta de cauza, ma intreb daca si citirea din memorie nu ar implica niscaiva jitter sau alte alea care conteaza in sunetul final ?!
nicumur
Post by nicumur »
Pai, tipul care face prezentarea zice ca nu :roll:
si Dan Lavry zice ca nu exista jitter la DA-10. Dar acest DAC-uletz, desi isi face banii din plin, e mult sub aparate care sunt jittaroase la greu ! :roll:
CC_TM
Post by CC_TM »
Zi-mi si mie un jitteros din asta, sa-l ascult si eu.
PS: presupun ca e si ieftin daca e jitteros :roll:
CC_TM
baga si tu pavilionul la, incep de la cel mai ieftin (si sunt exemple pe care le cunosc personal destul de bine), un HOLFI cu mutra de lemn si aspect banal, poate si la un UNICO CDE care poate iti va crea surprize grele la o comparatie cu DA-10, la un NorthStar Extremo, la un PIGreco CD1X a lui Mauro Mauri din Roma (solutie perfect clasica), la un Audio Aero Prima (pe viitor Concorde), la un Luxman din seriile cu SACD, la un Audio Aero Capitole Classic, la un Audio Aero SACD iar la urma baga pavilionul la un Accuphase pentru senzatii tari. Nici unul din astia nu se lauda cu jitter zero sau eliminat. Multi amintesc de un jitter redus. Nici unul nu are vreo solutie revolutionara si nici nu trage prin buffere. Insa asculta-le si judeca singur.
