Combine muzicale
Re: Combine muzicale
Nicumur ai reusit sa testezi Sony-ul ?!
Din pacate nu se alimenteaza si nu am avut timp de el.
combina monobloc din anii 70, AIWA AF-3090:
http://audiofilek.pl/index.php/home?sob ... obi2Id=837" onclick="window.open(this.href);return false;
Unul dintre ultimele micro-sisteme de valoare produse de Technics, inainte de a intra pe panta descendenta ce a dus, intr-un final, la disparitia sa ca brand...
Acest spectaculos SC-HD505 apare in catalogul lor din 2000 si este detinator, printre altele, de bi-amplificare, finisaj de lux din aluminiu si otel inoxidabil si cu iluminare laterala albastra, difuzoare de bass din material compozit din polipropilena si mica cu sensibilitate de 90 dB (la 2x23 W RMS putere totala)
Lista mai detaliata a specificatiilor, aici:
Tuner
* RDS
* 39 FM memories
* Multi-Message Display Function
* Weekly Programmable Audio Timer
* Blue Illumination
* Stainless Steel Finish
Amplifier
* Multi Drive Bi-Amp for Outstanding Sound Quality and Power
* BLFS (Brisk Low Frequency sound) Circuit for Dynamic Bass Sound
* New Class A Circuit for High Quality sound
* Fine Tweeter control
* Ecomode
* Blue Illumination
* Full Remote Control
Tape Deck
* High Speed FF/Rev
* Dolby B NR
* Hi-Speed TPS
* Auto Tape Selector (Metal / High Position / Normal)
* Blue Illumination
CD Player
* MASH 1-Bit DAC and Digital Servo System
* CD TEXT ready
* A1 Edit for easy CD-To-Tape editing
* Optical Digital Output Terminal
* Blue Illumination
Speakers
* 2-Way Bass-Reflex Speaker System with 4-3/4"
* Woofer and Tweeter
* Mica composite Woofer
* Balanced Dome Tweeter
* Light Brown Cabinet Speakers
* Bi-Wire Speakers
Tuner
* RDS
* 39 FM memories
* Blue Illumination
Amplifier
* Ecomode
* Blue Illumination
Tape Deck
* High Speed FF/Rev
* Dolby B NR
* Hi-Speed TPS
* Blue Illumination
CD Player
* CD TEXT ready
* Blue Illumination
Speakers
* Bi-Wire Speakers
...iar acest SC-HD550 din 2001 chiar cred ca a fost ultimul lor micro-sistem reusit!
cateva specificatii interesante:
VGCA (Variable Gain Control Amplifier) for High S/N ratio (98 dB)
Multi-Drive Bi-Amp
High Sound Quality with Balanced Dome Tweeter & Formed PP Mica Woofer
RDS FM/AM Tuner
2 x 25W RMS
Horizontal Loading Cassette
Multi-Drive Bi-Amp
RDS FM/AM Tuner
2 x 25W RMS
Panasonic SC-PM22 ( (p)2000)
De fapt, un Technics mai "budget friendly" lansat sub denumirea Panasonic, insa avand destule din specificatiile combinelor Technics, precum wooferele din PP-Mica, condensatori TA-KEH II (utilizati in special in receiverele Technics de top!), finisajul superb din aluminiu al partii frontale si iluminarea albastra a ecranului electronic. Ineditul acestui micro-sistem era asigurat de panoul retractil electric, actionat digital, de la sectiunea potentiometrelor de volum si ton.
Puterea era de 2X20 W RMS si tin minte ca am avut ocazia sa il "ascult" putin, ramanand impresionat de finetea inaltelor...
Sony CMT-SD3 (1999-2000):
Versiunea de baza era cu unitate CD-radio, dar la cerere se puteau adauga atat MD cat si tape deck, in conformitate cu designul microsistemului.
Cateva specificatii:
2X25 W (RMS 10%) + 50 W Subwoofer (RMS 10%)
DBFB bass boost
Simulator sunet surround
Incinte satelit 3-D iluminate, cu iluminare reglabila la culoare si starlucire
Panou frontal aluminiu
...si versiunea stereo 2.0 (CMT-SD1), cu boxe de calitate cu tweetere dom cu matase si woofere din kevlar:
DBFB bass boost
Sony MHC-6700 (1991):
Digital Sound Processing
Bi-Amp
2X60 W (RMS)
Dolby B/C, HX-Pro
Boxe 3 cai, cabinet separat pt. medii si inalte
Bi-Amp
2X60 W (RMS)
Dolby B/C, HX-Pro
nu ma pot abtine sa nu prezint si scula pentru care l am tarat pe tata de mana de 3 ori la magazinul Panasonic si pana la urma a fost mea.
desi pare inscrisa la portabile nu era deloc portabila , foarte adanca , grea, amplificator separat inalte/joase, un sunet cald si decent pentru un plastic, da stiti cum e, parca nici plasticul nu mai e ce a fost odata.
I miss it!
nu pot pune imaginea, pare a fi o problema, pun link ul:
http://www.shizaudio.ru/audio/details.php?image_id=3285" onclick="window.open(this.href);return false;
I miss it!
cablurile cu sens.
cablurile cu sens.
comanr wrote:nu ma pot abtine sa nu prezint si scula pentru care l am tarat pe tata de mana de 3 ori la magazinul Panasonic si pana la urma a fost mea.
I miss it!
Am pus eu acum fotografia cu Panasonic RX-E300, felicitari sincere pt. achizitia din trecut!!... Adevarul este ca si eu visam frumos la acest microsistem compact, complet digital... Ma gandeam chiar sa-mi iau si o pereche de casti wireless ca sa fie totul mai Sci-Fi, intr-o vreme in care casetofoanele cu taste actionate manual (impinse) inca faceau legea
In orice caz, piesa de fatza era tare interesanta pentru acele vremuri (1995-1996, apare in cataloagele Panasonic de atunci). Iata cateva specificatii:
sistem de putere 4 amplificatoare, 4 difuzoare
telecomanda completa
deck autoreverse
Dolby B
Tuner digital (10 FM, 10 MW, 10 LW)
Egalizator presetat 4 moduri si S-XBS (bass boost)
putere: 60 W PMPO
merci brighty!
l am avut multi ani , la un moment dat l am vandut unui amic de liceu care in fiecare an aducea vorba de sistemul meu. pot sa zic ca imi pare rau ca l am dat(mai mult cadou), am realizat ca imi lipsea abia cand nu mai era. ma bate un gand de buy back
cablurile cu sens.
cablurile cu sens.
Sony Placido VF1 CD (1992):
2X55 W (DIN, 6 Ohm)
sintetizator de bass variabil
tuner 3 benzi cu 30 statii
CD 1-Bit D/A convertor
Filtru digital 45-Bit
Casetofon 2 capete
Sistem angrenaj 2 motoare
Dolby B/C, HX-Pro
Boxe Sony SS-VF 1 A, cu tweeter calota de 2,5 cm si woofer con de 17, 5 cm diametru
Conectori boxe auriti
2X55 W (DIN, 6 Ohm)
Casetofon 2 capete
Dolby B/C, HX-Pro
Mie imi placeau mult combinutele de tipul ala din anii 90" dar deja trecusem la componente separate de 430mm si le consideram aprioric inferioare.
Totusi nu de putine ori ramaneam uimit cat de placut sunau in comparatie cu linia din componente separate (Technics) si boxe mari (Unitra
Combinele reuseau un sunt echilibrat si placut, nu neaparat corect, precis.
Recunosc ca si eu am o slabiciune pentru micro-sisteme, pe cateva dintre modelele mele preferate tocmai le-am prezentat mai-sus. Dar, in general, imi place oricare lucru bine facut, cu pasiune si respect pentru muzica si ascultatorii sai, chiar daca nu se pune problema atingerii unor performante audiofile de calibru greu... Am o fascinatie/curiozitate proprie pentru solutiile ingenioase care inglobeaza tehnologie de calitate si design splendid intr-o carcasa de dimensiuni restranse, cu rezultate nu de putine ori surprinzatoare!... Cred ca asta tine mai degraba de arta miniaturilor asiatice, pe care, de asemenea, o apreciezpuf wrote:Mie imi placeau mult combinutele de tipul ala din anii 90" dar deja trecusem la componente separate de 430mm si le consideram aprioric inferioare.
Totusi nu de putine ori ramaneam uimit cat de placut sunau in comparatie cu linia din componente separate (Technics) si boxe mari (Unitra)
Asa este, combinele din anii '90, acelea negre si cu un design clasic fascinant, au fost indraznet de reusite. A mai mers treaba pana in prima jumatate a anilor 2000,apoi intreg domeniul audio, pe tot spectrul sau, a fost atins de decadere. Nu stiu daca MP3-ul a fost cel ce i-a dat lovitura de gratie, cat mai ales mofturile, fitzele si toanele consumatorilor de muzica. Dar, asta este deja un alt subiect de abordat (l-am mai "atins", sporadic, pe unele topicuri!)
Oricum, o combina audio reusita tehnic si estetic este uneori o buna solutie pentru un spatiu de auditie restrans, cum ar fi o sufragerie redusa de bloc comunist. Iar intr-un dormitor, pe noptiera, face minuni!
Am ales sa preiau din mers acest topic, pe care sa inserez poze si cateva pareri si specificatii tehnice, ca un remember, mai ales dupa o recenta vizita intr-un Altex unde am remarcat, absolut stupefiat, disparitia unui intregi etajere de combine muzicale stereo (s-o spun pe sleau, le-au "ras" pe toate de acolo!) AM CREZUT CA NU VAD BINE!! Am mai dat tarcoale de vreo doua ori prin magazin ca sa gasesc raftul, dar... nimic! Incepe sa fie clar ca ... muzica, asa cum o stiam noi, cei de o anumita generatie, incepe cu adevarat sa se duca naibii!!
Veti spune:"-Pai si ce ne intereseaza astea, ca noi oricum ascultam la sisteme hi-fi iar unii chiar si la hi-end?" Asa o fi, dar eu cred ca tot ce era legat de muzica se va schimba, deja s-a schimbat destul de vreo cativa ani pana in prezent, insa in continuare totul va merge din rau in si mai rau si ne va afecta iremediabil si pe noi, cei din nisha hi-fi... Nu stiu cata pasiune vom mai avea pentru asa ceva, cand totul in jurul nostru (muzical) va fi ruina...
Noul entertainment este dominat de plasme, LCD, televiziuni imbecile, tablete, smartphones si PSPuri, poate si de BluRay, dar intr-o masura mai mica. Cam asa sta treaba...
Scuzati off-topicul... revin in curand la subiect.
in primul rand in ruina este MUZICA ! Iar lucrul asta daca ma gandesc bine s-a intamplat concomitent cu evolutia pietei de aparate audio stereo asa cum ai mentionat, undeva la sfarsitul anilor 90 s-a produs o cadere totala in calitate pe piata aparatelor audio stereo. Muzica anilor 2000 nu mai poate fi retinuta, nu mai are nici o valoare si nici un mesaj dar in primul rand nu mai are nici o valoare artistica si nu in ultimul rand nu mai exista nici inspiratie, daca vom cauta in spatele fiecarui "hit" vom gasi plagiat dupa chestii vechi furate si recosmetizate. Muzica pop, disco, comerciala, etc, este un fel de barometru si in opinia mea reprezinta mai mult decat ne imaginam, as putea spune ca este o amprenta a civilizatiei.brighty wrote:Am ales sa preiau din mers acest topic, pe care sa inserez poze si cateva pareri si specificatii tehnice, ca un remember, mai ales dupa o recenta vizita intr-un Altex unde am remarcat, absolut stupefiat, disparitia unui intregi etajere de combine muzicale stereo (s-o spun pe sleau, le-au "ras" pe toate de acolo!) AM CREZUT CA NU VAD BINE!! Am mai dat tarcoale de vreo doua ori prin magazin ca sa gasesc raftul, dar... nimic! Incepe sa fie clar ca ... muzica, asa cum o stiam noi, cei de o anumita generatie, incepe cu adevarat sa se duca naibii!! Mai intai casetele, walkman-urile, casetofoanele deck, CD-urile originale, apoi si cele CD-R, CD walkman-urile, pe urma mp3 playerele, o usoara coborare observ ca o au si castile, pentru ca bomba zilei s-o reprezinte acest "ultim bastion" al stereofoniei de masa de odinioara, reprezentat de combine... Se pregatesc de extinctie, cu joc de glezne, si boomboxurile... nici o grija!
Interesant ce se intampla la ora actuala, nu ne punem pe noi "moshii" la socoteala (oricum suntem atipici si nereprezentativi) - tineretul incepe sa refuze gunoiul mizerabil cu care e indesat si multi prefera muzica veche incepand chiar cu anii 90 si mai in spate. Este un semn puternic deoarece in mod normal omul in tinerete asimileaza orice forma de cultura sau non-cultura care-l inconjoara si indiferent de calitate, complexitate sau lipsa de complexitate, instinctul de imitatie si integrare in turma fiind extrem de puternic, practic o caracteristica de baza existentei omului care nu a evoluat nici un milimetru in intreaga istorie cunoscuta de aproximativ 7 mii de ani. Fenomenul asta de respingere care evident nu este majoritar dar exista, arata cat de jos a ajuns muzica in prezent! Sper ca intr-o zi sa se produca saturatia si un fenomen in lant sa schimbe situatia. Iar una dintre principalele cauze ale situatiei sunt banii si cultivarea lacomiei stupide, muzica comerciala transformandu-se in masina de produs bani. In astfel de situatii este distrusa creatia artistica, inovatia, originalitatea si intr-un final valoarea artistica, o chestiune delicata si relativa care se poate manifesta chiar si atunci cand produci muzica batand cu batul intr-o cratita pe marginea santului sau poate lipsi cu desavarsire chiar si atunci cand ai zece tone de super scule de muzica si o armata de specialisti tehnici.
Revenind la subiect, vreau sa amintesc de combinele Panasonic facute dinstr-un singur corp si carora le spuneam "bombe" sau "obuze" in anii 90, acele combine ovaloide (si grele!) care aveau si CD player, culoare negru in toate cazurile si care desi la modelele mai mici aveau doar cate un singur difuzor mic de banda larga pe fiecare canal, totusi sunau excelent. Toate aveau chiar si telecomanda.
Sub brandul Panasonic s-au fabricat scule de o calitate exceptionala, chiar si plasticul acestora era deosebit calitativ si turnat perfect fatza de alte branduri. Dau un exemplu de plastic Matsushita, cass deck-urile Technics din anii 90, mecanica integral din plastic dar excelenta, fiabile, impecabil executate. Erau alese de cei care trageau casete "industrial" deoarece rezistau cel mai mult, costau decent si chiar si trageau decent. Trageau mii de casete cu deck-urile astea pana se ducea motorasul si cureaua dupa care le schimbau si mai functionau inca pe atat. Tin minte ca mai intrebam pe cate unul de ce foloseste numai deck-uri Technics si-mi raspundea ca incercase cu alte branduri dar nu rezistau nici jumatate si nici nu sunau la fel de bine la aceeasi bani.
La combinele Panasonic (fiind practic aceeasi firma) au folosit toata expertiza Technics si s-au mai specializat in ceva, difuzoare mici si de calitate. In prezent plasmele Panasonic au cele mai bune difuzoare si cel mai bun sunet intre panourile plate TV de orice fel. Ma refer la sunetul atat cat se poate obtine din difuzoare de marime mica si putere scazuta in carcase minuscule.
