In urma unor schimbari radicale in sistemul audio, pun la vanzare urmatoarele:
1) Amplificator NAD C326BEE - 2x50W, 4-8ohmi, cumparat de nou acum cca 4 ani, sunet bun, folosit foarte putin, cu telecomanda originala, pret 1200 ron
http://i.imgur.com/r1GoBVk.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/5j3muGk.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/Qm8OVUE.jpg" onclick="window.open(this.href);return false;
2) CD/SACD/DVD player NAD T535 - cumparat de nou acum cca 4 ani, sunet bun, folosit foarte putin, cu telecomanda originala, pret 800 ron
http://i.imgur.com/POQ4w79.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/FwGNVrR.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/UZm3Zth.jpg" onclick="window.open(this.href);return false;
sau impreuna NAD C326BEE + NAD T535 la pretul de 1900 ron
http://i.imgur.com/xmdBTuL.jpg" onclick="window.open(this.href);return false;
3) Amplificator Luxman L-435 functional ok, aspect vintage, sunet bun, 2x100W in 8ohmi, 11kg, pot furniza si manualele (owner si service) in format pdf - 650 ron pret fix (comparati acest pret cu pretul de pe ebay)
http://i.imgur.com/Yd3Yf96.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/Yk32AQ1.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/mhKlBNd.jpg" onclick="window.open(this.href);return false;
4) Boxe Celestion Ditton 33 - 15kg/buc, 25W, max 50W, 4-8ohmi, au fost colantate, aspect ok, suna bine, pret 500 ron
http://i.imgur.com/sGlDN9E.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/kFpyD5j.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/YUT81sN.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/ybecBKM.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/5FEsXxd.jpg" onclick="window.open(this.href);return false;
5) Boxe Celestion (?) - Nu stiu ce model sunt, poate sunt DIY, seamana leit cu modelul Celestion 88 dar au dimensiuni mai mici: cca 75 cm inaltime, 15 kg/buc, am inteles de la persoana de la care le-am luat ca ar fi pe 8ohmi, nu stiu ce putere au, suna bine, din constructie nu sunt prevazute cu plase de protectie, drept picioruse au niste discuri de plastic (probabil le veti putea inlocui cu spike-uri) - 450 ron pret fix
http://i.imgur.com/Hg7N0Ao.jpg" onclick="window.open(this.href);return false;
6) DVD player Sony DVP-SR750H in cutie cu telecomanda, folosit foarte putin - pret 120 ron
http://i.imgur.com/VxsTsJF.jpg" onclick="window.open(this.href);return false;
7) Pick-up (turntable) Onkyo CP-1116A - functioneaza dar se invarte mai repede decat ar trebui, necesita schimbare de curea, posibil si alte interventii pentru reglarea vitezei, altfel are doza ok, sunet ok, capac cu ceva zgarieturi dar nu spart, se vinde deci pentru reparatie sau pentru piese - pret 120 ron
http://i.imgur.com/lewqse2.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/U2Iff9b.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/2w89xnY.jpg" onclick="window.open(this.href);return false;
Nu trimit in tara. Predare doar personala cu proba in Bucuresti str. Carol Davila (zona intre metrou Eroilor si Academia Militara). Stabilire intalnire cu cel putin o zi inainte, la tel 0743330667.
Vand NAD, Luxman, Celestion, Onkyo, Sony:
- pisiculverde
"Music is feeling" - Salvador Sobral
- pisiculverde
Re: Vand NAD, Luxman, Celestion, Onkyo, Sony:
Update:
1) Amplificator NAD C326BEE - 2x50W, 4-8ohmi, cumparat de nou acum cca 4 ani, sunet bun, folosit foarte putin, cu telecomanda originala, pret nou 1100 ron
2) CD/SACD/DVD player NAD T535 - cumparat de nou acum cca 4 ani, sunet bun, folosit foarte putin, cu telecomanda originala, pret nou 700 ron
sau impreuna NAD C326BEE + NAD T535 la pretul de 1700 ron
3) Amplificator Luxman L-435 functional ok, aspect vintage, sunet bun, 2x100W in 8ohmi, 11kg, pot furniza si manualele (owner si service) in format pdf - foarte curat pe dinauntru, finalii au fost schimbati - 650 ron pret fix (comparati acest pret cu preturile de pe ebay)
4) Boxe Celestion Ditton 33 - 15kg/buc, 25W, max 50W, 4-8ohmi, au fost colantate, aspect ok, suna bine - pret 500 ron fix
5) Boxe standfloor / coloana - Boxe cel mai probabil executate DIY, au cca 75 cm inaltime, 15 kg/buc, sunt pe 8 ohmi, nu stiu ce putere au, suna bine, din constructie nu sunt prevazute cu plase de protectie, drept picioruse au niste discuri de plastic (probabil le veti putea inlocui cu spike-uri). Aspect 8.5/10, functionare 10/10 - pret fix 450 ron
6) DVD player Sony DVP-SR750H in cutie cu telecomanda, folosit mai putin de 10 ore. Perfect functional, intrare usb, iesire hdmi, iesiri rca, se poate folosi ca: dvd player, cd player, conversie cd => mp3 cu salvare pe usb, ascultare mp3 de pe usb )dar este necesara utilizarea telecomenzii + meniului pe tv pentru a comuta intre alegerea sursei disk/usb) - pret nou 110 ron
7) Pickup-ul nu mai este valabil (s-a dat)
Nu doresc schimburi. Nu trimit in tara. Predare doar personala cu proba in Bucuresti str. Carol Davila (zona intre metrou Eroilor si Academia Militara). Stabilire intalnire cu cel putin o zi inainte, la tel 0743330667.
Din pacate timpul nu imi permite sa ofer auditii. Pot oferi doar proba de functionare la cumparare. Pentru aproape toate modelele prezentate puteti gasi caracteristici tehnice pe net, precum si clipuri pe youtube pentru a va face o idee. Ofer si pretind seriozitate. Contactati-ma doar daca sunteti hotarati sa cumparati.
- Tarabostes
Sunt interesat de boxele Celestion Ditton 33. O proba scurta cred ca ar fi relevanta si binevenita.
"Fraged trancotar"
- pisiculverde
Multumesc pentru interes. De la ultima postare am facut poze cu:
- difuzoarele de medii: http://i.imgur.com/mdwMg8K.jpg" onclick="window.open(this.href);return false;
- difuzoarele de basi: http://i.imgur.com/QFE9GV5.jpg" onclick="window.open(this.href);return false;
- filtrele: http://i.imgur.com/VXTHQ09.jpg" onclick="window.open(this.href);return false;
Atat difuzoarele cat si filtrele sunt cele originale. De asemenea condensatorii sunt cei originali Elcap (nu au fost inlocuiti). Probabil ca dupa inlocuirea condensatorilor sunetul va avea de castigat.
Boxele functioneaza ok, insa evident ca suna diferit in functie de amplificator si de cabluri. De asemenea, preferintele si asteptarile fiecaruia in ceea ce priveste sunetul pot fi diferite. Eu le-am ascultat cu Denon, Luxman, NAD si cu un amp single ended cu lampi EL34. Cel mai bine s-au potrivit cu Denonul si cu lampile, dar asta este doar dupa urechea mea.
Pentru a va face o idee despre cum suna Ditton 33 (nu ale mele, ci altele) puteti cauta pe Youtube si veti gasi clipuri unde sunt imperecheate cu un amp Sansui si cu un amp pe lampi.
Va pot face proba de functionare la cumparare, cu scopul de demonstra ca boxele functioneaza. Daca sunteti hotarat sa cumparati, stabilim intalnirea, veniti cu banii, va fac proba si le luati acasa
Imi cer scuze, insa timpul meu este foarte limitat si nu am cum sa asigur auditii, deci singura modalitate de vanzare este cea descrisa anterior.
- Tarabostes
Multumesc pentru raspunsul promt.
Inteleg ca timpul e o problema. Am studiat cat de cat forumurile si am urmarit cu interes postarile de pe Youtube deci imi sunt cunoscute.
Imi doresc un upgrade pentru Heco Superior 640... un upgrade vintage si cu un buget modest, in mod cert..
Vreau sa le "imperechez" cu un amp onkyo integra 8850 si un cd player onkyo integra dx 6660. In acest moment ma sacaie faptul ca desi am incercat pozitionari diferite ale boxelor( ele fiind pe standuri) basul este inert, mediile fiind mult prea prezente in punctul de auditie.
Poate au nevoie de revizie a filtrelor.. poate asa suna ele in compresie..
Sunt impotriva folosirii eq... si ca drept consecinta mi-am rupt oasele mutand mobila prin casa in cautarea acusticii optime.
Vreau un sunet natural, cald, curat echilibrat insa fara pretentii audiofile
Totusi nu pot sa fiu 100% sigur pana nu le aud.
Nu vreau sa par neserios insa daca imi plac cu siguranta le voi cumpara.
Poate in viitorul apropiat timpul nu va mai fi o problema.
"Fraged trancotar"
- pisiculverde
Ii multumesc colegului Tarabostes pentru vizita.
Din pacate azi la proba de functionare tweeterul uneia din boxe se auzea mai slab decat la cealalta, iar la o ascultare mai atenta se pare ca intreaga boxa canta un pic mai incet decat cealalta.
Drept urmare voi retrage boxele de la vanzare, urmand sa ma ocup de o eventuala reparatie cand voi avea timp.
deci:
4) Boxele Celestion Ditton 33 nu mai sunt valabile, am renuntat la vanzare
deci:
- Tarabostes
Multumesc pentru timpul acordat!
Imi pare rau ca nu a fost sa fie..sper sa poata fi remediata problema...
"Fraged trancotar"
- pisiculverde
Cu parere de rau, din motive ce tin de lipsa timpului necesar pentru a ma ocupa de vanzari, ma vad nevoit sa retrag de la vanzare pe termen nedefinit toate cele enumerate mai sus. In plus, asa ma voi putea bucura in continuare de ele
Topicul se poate inchide, multumesc.
