On the same floor as the two rooms mentioned was the most interesting looking speaker I saw at this year’s CES, and it also happened to sound fairly good. This was the $30,000.00 Silbatone Aporia Horn driven by Silbatone electronics. For lack of a more eloquent description, this reminded me of a B&W Nautilus on steroids. The sound was quite captivating though as it truly did seem to go full-range with no noticeable suck out in any particular frequency range. I sat for quite a while trying to convince myself that this would pass muster with Paula on the WAF. Perhaps in a different and darker color it would look a bit better. With the 3-point star at the front of the full range driver, there was a distinct feeling this was a speaker designed by Mercedes Benz. It uses a customized flat-cone Manger driver from Germany, and is geometry-optimized for smooth wave flow and compact form.
''Chestia'' aia este urata la modul profesional
Pacat,dincolo de virtutiile exceptionale care probabil le are,cred ca se adreseaza ca si prezenta doar budistilor zen care sunt imuni la cele vremelnice (sau ar trebui).Respect pentru efort
