Vand Moon, Sony, Jamo
PolyGram
Post by PolyGram »
Amplificator Simaudio Moon i1 - 900 E
Amplificator Sony 940QS, UK Edition, negru - 150 E
Boxe Jamo D570, Limited Edition, negre - 350 E
Paca antivibratii by chrissugar - 130 E
Detalii si poze - la cerere.
PolyGram
Re: Vand Moon, Sony, Jamo
Post by PolyGram »
La pretul de 900 euro pentru ampliful Moon ofer bonus placa antivibratii.
PolyGram
Post by PolyGram »
Pret nou, redus pt Moon - 800 euro (fara bonus)
Using numerous technologies found in our other highly sought after integrated amplifiers, the i1 produces an astonishing level of sonic performance with no equal in its price range.
http://www.simaudio.com/en/product/58-i ... ifier.html" onclick="window.open(this.href);return false;
Significant Design Features:
o An oversized power supply using a custom toroidal transformer design
o Rated output of 50 watts/channel into 8 Ω and 100 watts/channel into 4 Ω
o 6 line-level inputs including a front-mounted 1/8” mini-jack for personal media players
o Headphone output on ¼” TRS jack located on the front panel
o Remote control operation
o RS-232 port for (i) full unsolicited bidirectional feedback and (ii) firmware updates
o IR input for external control
o SimLink controller port for 2-way communications with other compatible MOON components
o Class A output to 5 watts for greater efficiency
o PCB w/ pure copper tracings & gold plating that yields low impedance characteristics
o Optimized selection of very high quality electronic components
o Heat-sink free design incorporating an all-aluminum chassis for evenly distributed heat dissipation
o Rigid chassis construction to minimize the effects of external vibrations
o Top cover is mounted with countersunk screws
o Designed to be powered up at all times for optimal performance
o Low operating temperature to ensure a longer than normal life expectancy
o Includes CRM-2 remote control.
PolyGram
Post by PolyGram »
Sunt disponibile in continuare doar ampliful Moon si placa antivibratii.
PolyGram
Post by PolyGram »
Reducere de Sarbatori...
Ampliful Simaudio Moon i1 la doar 750 Euro
PolyGram
Post by PolyGram »
Nu mai este nimic disponibil. Se poate inchide/sterge. Multumesc
