Amplificator pe lampi si strap-uri pt boxe
PolyGram
Post by PolyGram »
1. strapuri pentru boxe Chord Signature - pret 300 lei (noi sunt 100 lire)
2. amplificator pe lampi Xindak MT3 - impecabil, pret 450 euro( de nou costa 850)
Foarte bine si frumos lucrat, cu piese de calitate. Raport calitate/pret - imbatabil.
Vine cu capacul pentru protectia lampilor, manusi albe si lampi de rezerva: lampa de preu ECC83 si 2 lampi defazoare NOS 6SN7.
The integrated tube amplifier MT-3 is somewhat special because it enables you to switch between triode coupling (2x18 watts) and standard pentode connection (2x40 watts).The main reason to benefit from this option is that the lower output power (in triode mode) offers decreased distortion, increased frequency response and a wider dynamic range while the pentode mode offers higher output power.
Additionally, this amplifier is equipped with an ALPS volume potentiometer and a rotary switch that activates high quality relays for switching between inputs. In addition, the MT-3 is applied with a powerful toroidal transformer in the power supply that has a lower magnetic field than normal transformer.The sound perceived is balanced, delicate and fluid.
http://www.highfidelityreview.com/xindak-mt-3.html" onclick="window.open(this.href);return false;
http://www.xindak.com/en-us/product_det ... ductID=337" onclick="window.open(this.href);return false;
- doua etaje finale alimentate prin redresoare separate pe fiecare canal
- reglaj independent al tensiunii de negativare pe fiecare lampa EL34(se scapa de isteria cu imperecheatul)
- reglaj al etajului defazor - este montaj cu a doua trioda cu grila la masa
- comanda surse cu relee
http://www.hdaudio.ca/HDAudio/XINDAK_MT ... _SALE.html" onclick="window.open(this.href);return false;
“The Xindak MT-3 offers 40 watts (pentode) and 18 watts (triode) of liquid tube goodness using the sweet sounding EL-34 output tubes.
“It just loved vocals, male or female, string instruments and piano solos. ...this amp was extrememly quiet in my system. I was very impressed by it’s silence not only because it is a tube amplifier, but whether tube or solid state this still was one quiet amp. Xindak has doen a great job with this interated tube amplifier.”
Affordable Audio Review
PolyGram
Re: Amplificator pe lampi si strap-uri pt boxe
Post by PolyGram »
Strapurile Chord s-au dat.
Amplif-ul este disponibil in continuare.
PolyGram
Post by PolyGram »
Nu mai este nimic disponibil. Se poate inchide/sterge. Multumesc
