Vand Grado, Creek, Moon, Unison Research, Sugden
PolyGram
Post by PolyGram »
1. Doza GRADO Reference Platinum 1
Aproape noua, in cutie, extrem de putin folosita, cred ca nici nu este rodata.
Pret: 900 lei
2. Preu de doza CREEK OBH 15 mk II
Impecabil, ca nou, in cutie. Multiple reglaje pentru doza MM si MC
Pret: 1.400 lei
3. Amplif integrat MOON i-1
Impecabil, culoare neagra, telecomanda.
Pret: 750 euro
Un amplif pur si simplu fabulos de la renumita firma Simaudio. Are un sunet neutru, foarte curat si precis, dar in acelasi timp foarte rafinat si muzical. Pentru boxe Spendor sau Harbeth este prima alegere. Se potriveste bine si cu boxe Martin Logan, Piega, Focal.
https://www.stereophile.com/integrateda ... index.html" onclick="window.open(this.href);return false;
https://www.soundstageaccess.com/equipm ... oon_i1.htm" onclick="window.open(this.href);return false;
- Configuration: Single-ended
- Class of operation: A/AB
- 6 line-level inputs including a front-mounted 1/8” mini-jack for personal media players.
- Headphone output on 1/4” jack located on the front panel.
- “Class A” output to 5 watts for greater efficiency.
- Precision matched proprietary MOON Bipolar output transistors for improved bass response and accurate sonic reproduction.
- Low operating temperature for an ultra-long life expectancy.
- Rigid chassis construction to minimize the effects of external vibrations.
Output Power at 8Ω: 50 Watts per channel
Output Power at 4Ω: 100 Watts per channel
4. Amplif integrat pe lampi Unison Research SIMPLY TWO - editie speciala cu autograf!
O bijuterie de amplif cu sunetul magic al lampii EL 34 - "regina lampilor".
Impecabil. Ca nou. Al doilea proprietar. Putin folosit intr-un sistem auxiliar.
Spre deosebire de alte amplifuri pe lampi, chiar si de la Unison Research, are iesire pentru boxe de 4 si 8 ohm. Este un lucru esential la amplifurile pe lampi! De asemenea, are selector pentru a asculta cu reactie negativa sau fara.
In plus, este Editie Speciala cu semnatura lui G. M. Sacchetti!
Pret: 900 euro
5. Boxe SUGDEN LS 21
Impecabile, ca noi, in cutiile originale.
Nu sunt pretentioase la amplificare, sunt usor de condus. Datorita constructiei speciale a cabinetului, au un bas impresionant. Se pot apropia foarte mult de peretele din spate ceea ce le ofera un avantaj in camere mici. Se potrivesc tonal cu foarte multe amplifuri: Naim, Simaudio, Creek, Atoll, Primare, Classe, Exposure. Le recomand cu Sugden A 21SE si cu lampase pentru un sunet magic!
Pret: 1900 euro
http://neophonics.com/?p=50" onclick="window.open(this.href);return false;
Description: Two-way floor standing with integrated plinth.
Cabinet Design: Tune tapered quarter wave.
Cabinet Construction: Hand-made glued and pressed locking mitre joints.
Sensitivity: 90dB 1 watt one metre.
Nominal Impedance: 8 ohms.
Frequency Range: 25 -20000Hz.
Crossover Point: 2000Hz.
HF Drive Unit: 28mm Ferro fluid cooled.
LF Drive Unit: 160mm Hybrid Magnet vented motor, cast basket 54mm voice coil.
Dimensions: 100cm x 22.5cm x 24.5cm including hand made spikes (HWD).
Boxed Weight: 25 kgs each.
6. Placa antivibratii by chrissugar.
Pentru audiofilii cu pretentii.
E o placa antivibratii potrivita/gandita pentru surse in special: pick-up, cd-player. Sunetul e mai curat, totul e mai clar, microdetalii mai evidente, focus, separatie mai precise.
Dimensiuni: 48/35/5 cm
Greutate: 12 kg
Pret: 500 lei
Preturi negociabile. Detalii si poze la cerere pentru cei interesati.
Tel.: 0747111473
ZalinaZix9
Re: Vand Grado, Creek, Moon, Unison Research, Sugden
Post by ZalinaZix9 »
Poți face un tutorial video care să-l pot descarca cu save from net mp3cum să te folosești de tot ce vinzi si să faci o descriere video la produs?
Dadix
Post by Dadix »
Suspectez ca utilizatorul +ZalinaZix9 este un "robot" ce posteza reclama pe diferite site-uri.
La o cautare pe net dupa acest nume apar lucruri corelate cu aceasta descarcare in format video sau audio, dar nici o discuție adevărată cu alti utilizatori de pe acele site-uri.
ZalinaZix9: Iubesc să caut informație nouă pentru creierul meu. Pasionată mai mult ceva ce este contrariul mie, ca mașinile de exemplu.
https://www.google.com/search?q=ZalinaZ ... 0&bih=1067" onclick="window.open(this.href);return false;
Se inscrie pe toate forumurile, de orice, de la culinar, culturism, pescuit, bucatarie pana la orice fel de forum gaseste.
Daca e un program tip "robot" mi se pare foarte sofisticat.
Dadix
Post by Dadix »
@momolo uite chiar si pe acel site de unde
ai luat acel citat "utilizatorul" da un link de reclama la https: ro.savefrom. net unde e ceva legat de un downloader .
Preturile daca sunt discutabile (si in mod cert, da) mi se par de bun simt, acordate la piata. Evident, daca m-ar interesa ceva as oferta mai putin. Conteaza starea tehnica si alte aspecte.
Bafta la vanzare!
