CDA - noi metode de matritare-fabricare discuri
HQCD (HiQualityCD) format achieves high quality audio through the use of a polycarbonate plastic with improved transparency derived from LCD display manufacturing technologies enabling more accurate reading of the CD data. In addition, a special alloy is used as the material of the reflective layer instead of the standard aluminum. HQCD format CDs are fully compatible with standard CD players.
SHM-CD = The high quality SHM-CD (Super High Material CD) format features enhanced audio quality through the use of a special polycarbonate plastic. Using a process developed by JVC and Universal Music Japan discovered through the joint companies' research into LCD display manufacturing, SHM-CDs feature improved transparency on the data side of the disc, allowing for more accurate reading of CD data by the CD player laser head. SHM-CD format CDs are fully compatible with standard CD players.
Blu-spec CD format boasts a new approach to the faithful reproduction of music by utilizing the leading edge blue laser diode technologies optimized for the manufacturing of Blu-ray. During the manufacturing of CD, laser beam is pinpointed to encode data on the microscopic tracks molded on the polycarbonate plastic constituting the surface of the disc.
Compared to the conventional laser beam used for the manufacturing of standard CD, the blue laser beam used for the manufacturing of Blu-spec CD has a shorter wavelength, allowing more accurate encoding of the data. The use of the laser also eliminates the need to use cooling fans that cause vibrations. Furthermore, polycarbonate plastic optimized for Blu-ray is used to ensure accurate reading of the data. Amazingly and importantly, Blu-spec CD format is fully compatible with standard CD players.
Cele 3 de sus sunt noile variante de fabricare a unui CD audio de calitate audiofila.
Sambata am avut ocazia sa ascult si sa compar pe un sistem de referinta high-end (aprox. 100K euro) bazat pe Accuphase cap de serie (sursa Accuphase 800+801) + incinte Magellan, toate cele trei formate, in majoritate discuri cumparate direct din Japonia. In general jazz si clasica, case japoneze.
Concluzie personala, clasament:
1. pe primul loc, cel mai mult mi-a placut Blu-spec CD fabricat de SONY. O curatenie si o transparenta superbe. Nivel distorsiuni extrem de redus pentru un CD audio!
2. aproape la egalitate, in anumite cazuri poate cel mai bun a fost SHM-CD de care se pare ca se ocupa JVC, creatorii XRCD. Un sunet extrem de analog pentru un CD audio. Deci adjectivul principal este ANALOGIC, sunet cald, natural.
3. HQCD - un CD demo care trebuia sa arate minunea, nu mi-a placut deloc. Un sunet perfect....de mort! Undeva gasesc asemanare in stilul casei LINN, perfectiunea sintetica a sunetului. Insa alt disc mi-a placut dar totusi HQCD s-au aflat sub primele doua de sus.
De precizat - formatele astea (defapt nu sunt formate ci metode de fabricare/master) nu sunt totul, conteaza decisiv calitatea muzicii, modul cum a fost masterizata original. Acestea nu sunt decat suporturi mai bune (teoretic) pentru master. Asa ca la comparatie castiga defapt discurile cu cel mai bun material muzical din punct de vedere al inregistrarii originale, diferentele fiind enorme in acest sens!
Asa ca daca ma gandesc bine, posibil ca toate cele trei "forme" sa fie la fel de bune, conteaza ceea ce e pe ele si cum e pus!
Apoi am pus si niste XRCD....iar intr-un final am concluzionat ca XRCD-ul le cam bate pe toate......
Mie unul mi-a placut mult Blu-spec CD de la SONY. Insa depindea si de piesele inregistrate, nu toate erau bune (clasica, jazz si rock). Intrevad potential serios astuia daca se tin de el !
- HighEndFan
Re: CDA - noi metode de matritare-fabricare discuri
Asta ne mai lipsea, nu aveam si asa destule optiuni si variabile
Subscriu 100% - sunt fan XRCD precum stii (asta ar putea sa denote oaresice subiectivism ?) - am deja majoritatea titlurilor.momolo wrote: Apoi am pus si niste XRCD....iar intr-un final am concluzionat ca XRCD-ul le cam bate pe toate......
S-a uitat de mentionat si de formatul K2HD,..
viewtopic.php?f=2&t=33
Totusi trebuie avut in vedere ca SHM, HQCD, BLUE-spec difera de XRCD. Primele au suportul de inregistrare diferit: polycarbonate, LCD etc..., in schimb ce la XRCD-uri sunt masterizate diferit printr-o tehnologie proprie...
Pana la urma tot XRCD-urile raman cele mai bune!
Nu-s' de ce, dar as fi putut sa pariez ca vei ajunge la concluzia astamomolo wrote:Pana la urma tot XRCD-urile raman cele mai bune!
Cu toate ca din punct de vedere tehnologic si calitativ este cel mai bun suport la ora actuala, din cate am inteles, din pacate inca nu am vazut titluri din genurile muzicale preferate de mine
Eu am intalnit mai multe cazuri de oameni care o data cu un sistem audio mai bun si-au schimbat radical gusturile muzicale. Oricat i-ar deranja pe unii acest adevar, daca nu ai un sistem audio de calitate, nu poti aprecia si intelege cu adevarat anumite genuri muzicale.Cu toate ca din punct de vedere tehnologic si calitativ este cel mai bun suport la ora actuala, din cate am inteles, din pacate inca nu am vazut titluri din genurile muzicale preferate de mine
Am un sentiment ''neplacut'' ca sunt foarte adevarate aceste vorbe.Tine numai de noi sa fim prudentzi daca vrem sa ramanem la valorile noastre vechi (ce ne-a placut pana sa auzim un sistem care insufla viatza intr-o muzica care nu ne intereseaza in mod obisnuit prea tare).Eu sunt constient ca daca as avea un sistem serios gusturile mele muzicale s-ar muta bine catre spectrul jazz-ului (in formele lui ''moderne'' unde stilurile se intreparund si care le ascult totusi rar,chiar daca imi plac - ce am nu poate sa ma faca sa ma indragostesc de prezentza sonica a anumitor ''atmosfere'' sonore) si probabil as incepe sa agreez si vocea,mult mai mult decat o accept acum,aspect la care sunt foarte mofturos.momolo wrote:............... Eu am intalnit mai multe cazuri de oameni care o data cu un sistem audio mai bun si-au schimbat radical gusturile muzicale. Oricat i-ar deranja pe unii acest adevar, daca nu ai un sistem audio de calitate, nu poti aprecia si intelege cu adevarat anumite genuri muzicale.
Parerea mea e ca e vorba mai curand de "metode marketing" intr-un domeniu in care cifra de afaceri e in cadere constanta de 20% pe an, da cativa ani buni...
Cu schimbarea gusturilor muzicale odata cu achizitionarea unor scule "bune", perfect de acord, doar ca asta se intampla destul de "repede" nu ai nevoie de a vinde 3 case si doua terenuri pentru asta, un sistem "high-end trancotar" este suficient (de genul "Cambridge" )
Obelix
- si eu sunt de acord ca nu trebuie vandute 3 case si 2 terenuri insa nu sunt de acord cu "termenul cambridge" pentru descoperirea muzicii. Cred ca e nevoie de ceva mai mult decat genul asta de trancote chinezofile, dealtfel bune la pretul lor dar nimic mai mult de atat si insuficiente pentru intelegerea muzicii.nu ai nevoie de a vinde 3 case si doua terenuri pentru asta, un sistem "high-end trancotar" este suficient (de genul "Cambridge" )
Eu sunt genul de om care pana nu incearca nu crede. Avand in vedere experienta ta foarte bogata in domeniu (fata de care am tot respectul in modul cel mai sincer), pun o intebare poate prea naiva. Aproximativ cam la ce nivel incepe un "sistem audio de calitate" ? Asta totusi, pentru a dispersa orice iluzie ca-mi voi putea permite vreodata o configuratie care sa se incadreze in acest capitol sau macar sa se apropie de criteriul respectiv.momolo wrote: Eu am intalnit mai multe cazuri de oameni care o data cu un sistem audio mai bun si-au schimbat radical gusturile muzicale. Oricat i-ar deranja pe unii acest adevar, daca nu ai un sistem audio de calitate, nu poti aprecia si intelege cu adevarat anumite genuri muzicale.
in primul rand, nu cred ca am o experienta foarte bogata. Sunt altii pe acest forum (care scriu mai putin sau deloc) cu o experienta mai bogata.Eu sunt genul de om care pana nu incearca nu crede. Avand in vedere experienta ta foarte bogata in domeniu (fata de care am tot respectul in modul cel mai sincer), pun o intebare poate prea naiva. Aproximativ cam la ce nivel incepe un "sistem audio de calitate" ? Asta totusi, pentru a dispersa orice iluzie ca-mi voi putea permite vreodata o configuratie care sa se incadreze in acest capitol sau macar sa se apropie de criteriul respectiv.
Cat priveste nivelul pe care eu il consider minim pentru asazisa intelegere a muzicii (dealtfel si asta e un termen inventat de mine, nu stiu si daca e corect?!) as spune ca,
1. player CD minim decent undeva peste 2000 euro.
2. amplificator integrat minim decent undeva peste 3000 euro.
3. incinte acustice minim decente undeva peste 2500 euro.
4. cabluri necesare minim decente..... undeva peste 1000 euro (aici mi-ar sari la beregata unii trancotari!
5. pickup + pre phono + doza minim decente, undeva peste 2500 euro impreuna.
Toate de noi. Daca am discuta despre scule second hand nu am putea face estimari de pret.
Marantzofan, si eu spuneam pe vremuri ca nu-mi voi permite niciodata anumite lucruri. Realitatea mi-a demonstrat contrariul mai curand decat as fi crezut. Totul este sa vrei cu adevarat ceva si atunci sansele de implinire sunt infinit mai mari! Dar intrebarea reala este, daca merita, deca vrei cu adevarat asa ceva ?! (pentru ca pana la urma nu e decat o chestiune de prioritati si alegere).
Intr-un final, totul nu e decat o simpla chestiune de timp atata vreme cat mai respiram pe lumea asta.
Raspunsul dupa care astept de cativa ani buni de cautare pe diverse forumuri de specialitate. Recunosc ca pe moment am ramas fara rasuflare la vederea acestor cifre, insa si acest lucru imi demostreaza perfect cat de bine este pusa la punct intreaga industrie audio, dominata de arta dezinformarii si a marketingului de prost gust. Daca inteleg bine, tot ce se afla sub aceste sume nu-ti poate oferi, nu atinge acel standard pe care o poti numi incursiune in "nirvana audio". Mai exista si momente de adevar in viata care nu te fac mai fericit, insa reprezinta un punct de referinta, un reper, care iti arata iesirea din labirintul creat de departamentele marketing. Momentan ma aflu foarte aproape de intrarea in labirint si nu stiu daca am curajul sa pornesc pe acest drum. Criza economica mondiala imi va usura foarte mult adoptarea unei decizii corecte, dar foarte dureroase. Ghiciti care va fi acea decizie.momolo wrote:
4. cabluri necesare minim decente..... undeva peste 1000 euro (aici mi-ar sari la beregata unii trancotari!).
Momolo, iti multumesc foarte mult pentru raspuns.
