iDiamond - the device was created by Thomas Heyerdahl, who is a Norwegian jeweler. The world’s most expensive MP3 player is comprised of solid eighteen karat white and pink gold and is also covered with over 430 diamonds. The earplugs are also made from the same gold that the device is made from.
The iDiamond is said to be worth approximately twenty thousand pounds, which is approximately $40,500 USD
P.S Il incarci cu manele si reteta este completa !!!
Pina sa descarci mp3 pe iDiamond, le poti stoca temporar pe acest memory stick
The most expensive USB Stick is decorated with diamonds and gold and offers you to take 14 or 18 carat gold stick . Its retailed price is $ 3,500 (with diamonds) and $ 2,800 without them
Daca situatia ar fi invers, adica audiofilii majoritari si aia cu mp3-ul/ipod-ul in urechi aflati in minoritate, atunci ar aparea si Burmester batut in diamante cu mufe din aur masiv si carcasa de platina.
Intotdeauna se gaseste cate un "gigi" care sa le cumpere.
Se da si lant de aur bonus la chestiile alea ?!
