3D HDTV
3D HDTV
A luat o mare amploare fenomenul 3D, mai ales dupa ultimele creatii hollywoodiene in 3D. Principalii candidati
SONY http://www.i4u.com/article29809.html" onclick="window.open(this.href);return false;
JVC http://www.jvc.eu/3d_monitor/index.html" onclick="window.open(this.href);return false;
PANASONIC, TOSHIBA,LG - http://ces.cnet.com/8301-31045_1-104284 ... 7-1_3-0-20" onclick="window.open(this.href);return false;
Re: 3D HDTV
3D BLURAY
http://www.businesswire.com/portal/site ... ewsLang=en" onclick="window.open(this.href);return false;
ADAPTOR 3D
http://www.doremilabs.com/ftp/appnotes/ ... ersion.pdf" onclick="window.open(this.href);return false;
ADAPTOR 3D
Re: 3D HDTV
Panasonic videocamera 3D
http://gizmodo.com/5441912/panasonics-3 ... resurfaces" onclick="window.open(this.href);return false;
SONY 3D BD/CD player cu INTERNET
http://gizmodo.com/5442041/sony-bdp+s77 ... ontrol-app" onclick="window.open(this.href);return false;
Receiver satelit 3D
http://gizmodo.com/5442084/testing-the- ... gly-decent" onclick="window.open(this.href);return false;
Samsung 3D OLED display
http://gizmodo.com/5442237/samsung-3d-o ... paper-thin" onclick="window.open(this.href);return false;
Ochelari 3D
http://gizmodo.com/5443236/the-fashion- ... t-of-style" onclick="window.open(this.href);return false;
Receiver satelit 3D
Ochelari 3D
Re: 3D HDTV
ADAPTOR 3D numai pt TV Mitsubishi
http://www.electronichouse.com/article/ ... edium=side" onclick="window.open(this.href);return false;
JVC IF-2D3D1 STEREOSCOPIC IMAGE PROCESSOR
http://pro.jvc.com/pro/pr/2010/ces/if2d3d1_ces10.html" onclick="window.open(this.href);return false;
http://pro.jvc.com/pro/attributes/SEG/p ... 1203-a.jpg" onclick="window.open(this.href);return false;
3D PLAYERS
Da, SONY PSP3 este upgradabil 3D
http://www.electronichouse.com/slidesho ... /7764/1123" onclick="window.open(this.href);return false;
JVC 3D PROJECTOR
http://www.aboutprojectors.com/JVC-DLA- ... ector.html" onclick="window.open(this.href);return false; - $ 175,000 UNUL - PT 3D ai nevoie de ... 2
http://pro.jvc.com/pro/pr/2009/cedia/dlars4000.html" onclick="window.open(this.href);return false;
OPTOMA 3D READY projector
http://www.optomausa.com/PressRelease_D ... ress_id=96" onclick="window.open(this.href);return false;
PANASONIC 3D CAMCORDER
http://www.digitalcinemareport.com/node/1491" onclick="window.open(this.href);return false;
3D PLAYERS
JVC 3D PROJECTOR
Re: 3D HDTV
3-D e obsolete - welcome to 4-D
http://cineramax.com/" onclick="window.open(this.href);return false;
4-D se refera , in mod obisnuit, la un 3-D completat cu alte excitatii - fum, apa,tremor,etc - precum Universal si Disney au citeva prezentari -
For the uninitiated, "4-D" refers to a 3-D film (yes, you still have to wear those goofy glasses, called "OgreVision goggles" here) shown in a theater specially equipped to immerse viewers with an added dimension of sensory ticklers. Perfectly synchronized water spritzes, bursts of air, and other enhancements draw guests into the remarkable 3-D landscapes. Shrek 4-D takes it a step beyond with seats that move both horizontally and vertically. It’s not a motion simulator attraction per se, like Back to the Future or Disney’s Star Tours, but the seats do incorporate a surprising amount of motion, and Shrek 4-D straddles the line between a theatrical presentation and a ride.
Re: 3D HDTV
Romanii sunt mai cu motz si au numit tehnologia 6D, exista intr-unul din mall-urile dambovitene
http://www.libertycenter.ro/blog/?p=213" onclick="window.open(this.href);return false;
Re: 3D HDTV
La Piatra Neamt exista un cinema 7D, stiu ca ruleaza doar filmulete scurte, cu o durata cuprinsa intre 7 si 20 de minute. Nu am ajuns inca dar o sa ma duc din curiozitate
Re: 3D HDTV
XD sint versiuni mioritice ale lui 3D - acele filmulete scurte , cu scaune miscatoare, ploaie,cutremur, miros de gaze, impunsaturi,senzatie de obiecte miscatoare pe la picioare - gen blana ,etc ruleaza la americani de vreo 20 ani, fie in parcurile Disney, Universal, la Vegas, sau in mici cinematografe mobile. Si daca te gindesti, unele cinematografe 2D au aceste optiuni pe gratis ( miros de gaze, impunsaturi, senzatie de obiecte miscatoare pe la picioare - gen blana sobolan )
Re: 3D HDTV
http://hometheater.about.com/od/homethe ... tch_3d.htm" onclick="window.open(this.href);return false;
Re: 3D HDTV
http://www.aspenmediaproducts.com/Aspen ... fault.aspx" onclick="window.open(this.href);return false;
Re: 3D HDTV
3D la Bucuresti din Aprilie - http://www.adevarul.ro/financiar/Televi ... 77495.html" onclick="window.open(this.href);return false;
Re: 3D HDTV
Maimutele (footbalisti + cocotetv + jiji + etc) isi vor lua 3D sa se uite cu ochelaru la una bucata film care vine bonus cu instalatia, la ei in viloana, in living, sub grinda, intre semineu si un stalp de beton care trece prin canapea (ca ce nevoie aveau de proiect?!).
Dar am auzit ca nu mai au bani nici sa-si puna benzina in mertzane, deci 3D-ul va ramane trufanda de primavara. Sper sa nu se crape la transport avand in vedere soselele, sau ce-a mai ramas din ele.
Re: 3D HDTV
Player 3D - http://www.3dtv.at/Index_en.aspx" onclick="window.open(this.href);return false;
Re: 3D HDTV
Panasonic de 152" si 590 Kg !!!! (si peste 100K dolarei...pacat ca nu-mi intra pe usa!....
Apropos! O chestiune, la unii poate nu tine planseul 6 sute de kile pe metru patrat!)
http://hdguru3d.com/index.php?option=co ... &Itemid=59" onclick="window.open(this.href);return false;
