http://www.onhifi.com/product/niro_engines.htm" onclick="window.open(this.href);return false; - PREAMP and POWER
http://www.onhifi.com/product/niro_1000_integrated.htm" onclick="window.open(this.href);return false; - INTEGRATED
http://hometheaterreview.com/niro-nakam ... -reviewed/" onclick="window.open(this.href);return false;
To get to the 'root' of NIRO, you should know the parent company's name: Mechanical Research Corporation
In NIRO's 1000 Power Engine, each heat-sink is a sub-assembly containing a push-pull output transistor pair, mounted immediately adjacent to one another to ensure thermal parity. Nakamichi explains, 'Using a dedicated subassembly for each transistor pair promotes uniform, efficient dissipation across all the fins with no "hot spots".'
Nakamichi mounted the heat-sinks with specially-designed supports that prevent the transmission of vibration. These mounts use a custom-made, conductive, non-magnetic gold-plated alloy, while the heat sink fins vary in length. Thus, any resonance from external sources, including excitation due to a speaker's high sound pressure levels, will be 'diffused' over a range of frequencies. Moreover, the heat sinks are fitted with a 3mm-thick resonance-damping bar, the structure also ensuring uniform heat distribution, a reduction in the time required to reach stable operating temperatures, and the prevention of external vibrations from interfering with the audio circuitry.
